squeeforever
squeeforever's Avatar
02.28.2006, 10:27 PM
the angle wont cause any troubles. you will just have to relign it and such. your servo skid should work fine.
im not sure but it wont be to bad although proline makes an extended for such things.
the flm only comes with one since the rear is extended and not the front.
if you order it ASAP mike might be able to get it to you by at least saturday.
yes, the chassis braces are different and im not sure if your skid will work.
no and yes. the chassis was made to were you can mount them on top like most or on bottom for a lower cg if you want.
it should be pretty straight forward and you shouldnt have any troubles getting it together.
by the way, welcome to forums! you will certainly learn alot from here as all of us have and you will like it here im sure. its the best forum for brushless infor there is!
