Thread: Sidewinder SC
Ferret
10.23.2010, 01:34 PM
Originally Posted by ta_man View Post
Maybe some were already shipped. I got a notice from Tower regarding order payment and the order status is now "being picked and packed in the warehouse."
On another subject, one of the spec points on the Castle site regarding how many cells can be used says:
"Controller and motor max 2S. Controller alone with motor of lower KV max = 3S."
So the controller is good to 3S like we suspected.
But what about the motor? If a 4600 is good to 3S when using with a Mamba Max or Pro, shouldn't the 1410 1Y motor be usable on 3S with a controller that has higher current handling capability, like a MMP or Monster?
Maybe the limit is not because of current handling but because of a switching speed limitation.
I think that with a 4 pole motor the ESC needs to switch power to the winding twice as many times per rev compared to a 2 pole motor.
If that is correct, then running a 4800KV 4 pole motor on 3 cells would require the same switching speed as running a 2 pole 9600KV on 3 cells or a 2 pole 4800KV on 6 cells.
Maybe Patrick could enlighten us.
Avner.
