Manne
10.25.2010, 02:02 PM
"they arent any stronger than the xxl diffs, they are just a diffrent ratio"
I strongly dissagree,
look at this picture:
And this:
A stock 1/8scale savage diffs Vs BP.... No difference? Looks bretty much more beefy in my eyes
Currently Iīm using stock diffs, with alu cups, shimmed properly, no play and no binding.
My problem isnīt that the pinion is "jumping over" a few tooths on the ring gear. The problem is that the tooths are losening from the ringgear..
I have my slipper adjusted correctly, loooose, and I never land with throttle..
Back to the topic, does anyone know if there is a chance that the bp diffs would fit in the losi cases or revo hybrid cases?
I looked at the exploded views of the losi diffs but there was no information on what bearing size the lst diffs pinion and ringgear/cup uses..
If anyone knows the size I could compare it to the savage bearing sizes and see if there was a chance to make this work
