Thread: Sidewinder SC
Pdelcast
Pdelcast's Avatar
10.26.2010, 07:17 PM
Originally Posted by crazyjr View Post
Patrick, I have a 3+year old mamba max setup with a 4600kv CM 36 motor, I am planning to get a 4600kv 1406 and a 1410/3800kv for running in a stadium truck (associated T4). If i wanted to save money, I could just get the motors. Is there anything in the design of the sc sidewinder that the mamba max is missing? Would it perform better my mamba max? Just wondering if i really need to replace the esc, to get the most out of the motors. Thanks for any info
The MM is a great controller - - power handling of the SCT is close, but not quite the same as the MM. The MM has higher burst capacity than the SCT, but the SCT has a better thermal design than the MM.
I'd stick with the MM and save the money. Then get an SCT later if you want a less expensive option to the MMP.
Thanx!
Patrick del Castillo
President, Principle Engineer
