Thread: Sidewinder SC
Thomas Porfert
Thomas Porfert's Avatar
10.29.2010, 02:46 PM
Originally Posted by Bmr4life View Post
Yeah, can I put this in a rustler or 2wd slash on 3s?
Not really intended for 3s on the 2wd slash. ESC temps will get a little high along with motor temps. You would be very limited on gearing and may have to keep the run times under 5 minutes. The safest setup for a 3s on a 2wd Slash would be the soon to be released 1415/1Y 2400kv motor. With the extra length it will produce significantly more torque, handle higher wattage and increase efficiency. Much much lower motor temps and a lot more gearing options. You would need to run the Mamba Max or Mamba Max Pro.
Thomas Porfert
Castle Tech Support
