11.02.2010, 09:17 PM
The ICE is technically a 1C charger, but like you said, if you set the capacity higher it raises the maximium rate of charge. Assuming the pack can support a higher rate of charge this is fine to do. The pack will not become overcharged, since a LiPo charger will always stop at 4.2 V/cell- just make sure the # of cells is set right (obviously?).
