Originally Posted by bdebde
If using them for a diff, I would go with something better than the $1 avid bearings. I use the revolution ones for wheel bearings and change them when they get cruddy. My muggy eats diff bearings if they are weak, so I use NMB bearings in the diffs, they last much longer. You can get away with cheap bearings at the wheels... they are easy to change. Diff bearings take a bit more work to change, so go with better quality there.
+1 for that. I also run better quality bearings just in my diffs for the reason of harder to get to. Although, if you do normal diff maintenance, accessability is not much of an issue
