Finnster
KillaHurtz
Finnster's Avatar
11.15.2010, 12:20 AM
Couple more pix. Got the bulkheads attached as well as the str servo. Its purple, but will get stripped later. Just test fitting. Looks like the str is off a bit and will need different ball end mounts for proper clearance and to avoid bumpsteer
If you notice on the left, I fit the Mugen captured hinge pins on the lower arm. Fits like it was meant to be there. Needed a little filing around the stock arm brace to clear the arm, but I will just make my own billet arm brace later once the shape is confirmed. Want to figure a way to capture the upper arm pins as well. Have an idea for later..
