InsaneRC
InsaneRC's Avatar
11.15.2010, 02:55 PM
I can only add vehicle data (transmission, diff, tire info, etc) for vehicles I personally have or if people submit that data to me. So, if you know those values, post them and I'll add them.
For diff and transmission data, I need the gear tooth counts, not the final ratio number. I like to keep precision higher and a final ratio tends to have rounding errors.
For tire size, I need the overall diameter.
Check the FAQ page for more info...
Wheels: Ultra light 3.2" (82mm) diameter, 1.6" (42mm) wide
Tires: High grip bones, 4.5" (115mm) diameter, 1.57" (40mm) wide with
foam inserts
I can not find the diff and transmission gear tooth counts I am doing research on the buggy now
Mat
Eletric is the New Nitro!!
Traxxas E-Revo
Marui Big Bear
Ofna Ultra LX-1E
