Well, that depends on the top speed you want to hit. Plug some numbers into the calc and see what you get (
parameter solver may help more here).
Just keep in mind any gearing limits (motor size, motor mount adjustment, etc), and allow room for further tweaks (in other words, don't get a ratio that will put you at the upper/lower limit of spur/pinion choices).
