_dV
12.03.2010, 02:49 AM
Would probably be better off with a red spring and the plastic tube that comes with the stock shocks then that double spring? Would avoid that collar that rubs on the body of the shock at least.
I'm a bit dubious of those dog bones. The point where the shaft joins the ball is still the same thickness but the thick shaft won't provide much torsional flex and that could put even more stress on that join area.
