75amp Discharge For The Full Duratoin Of The Charge.
MindThoughts
75amp Discharge For The Full Duratoin Of The Charge. - 12.03.2010, 11:04 PM
Brandon-
How long do you think it will be until you can get the 75c Continuous Discharge Test up for us to see?
PS. Is there any posibility to have the Battery State 75c Continuous(Full Duration) and 150c 1second Burst. And to specifify that Continuous is for the full duration of the charge of the battery- and 150c is for 1second burst- Onto the wrapping of each lipo?
PS. Brandon has already stated that these 6500mah LiPo's can handle and are rated at exactly:
150c Burst for one second.
100c for ten seconds.
75c for the full charge of the LiPo.
Brandon- you must have done some testing to arrive at these numbers you gave us earlier in this thread. Is there any way you can post up the test that were already done which gave you these figures? By the way- you mention to me in a PM that you were having technical problems transfering your test over to a Digital Format(if I understood you correctly), But if you could even take pictures of different time frames of these test you performed already, and just post the pictures up- that would at least be something for us to look at. I think most of us would like to see your 75c Discharge for the full duration of the charge- Test. The 100c for ten seconds is awesome as well- The 150c 1 second burst would even be interesting to see. What are your thoughts on this? By the way- what are you using to do the 75c continuous discharge for the full duration of the charge?
Originally Posted by brandonwilcox View Post
Couple of you guys said that you would be more impressed if s standard LiPo for an RC car was used and not a larger brick pack. Well Big Squid RC actually did this back in June with one of our packs and it cranked over the car right away with ease:
http://www.youtube.com/watch?v=KfaryxeCNsI
Brandon
Hyper 9E And Losi 8ight-E. Each model with Full Matrix Concepts Inc Carbon Fiber Chassis & Kit. Xcelorin 2100kv + Xcelorin ESC & 1409 1Y Neu/Castle + MMM. 1344watt 40amp PowerLab 8.
