ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
12.06.2010, 01:28 AM
So is that pic with the Losi Rear hubs....? It looks close...
If if does fit right. Maybe reverse True Track the front as well and use C-Hubs? I just dislike the pillowballs...
I will ask my dad to ask the guy on his route. But in the past the guy has offered to make stuff, no ???
I have been working on Losi 17mm/8mm hubs onto the Traxas 6mm CVDs. I got some 6mm/8mm CF and some spare time while I wait for my replacement FLM arm. I also have some Hot Bodies Shafts that are the same length as the Traxxas CVD shaft alone perfectly. But I need to find and axle that works correctly. I saw Mr. Crash had to shim his LST2 axle way too much for my liking. and they are the same as the 8ight axles... BTW I made captured hinge pins so bye bye E-clips
Whats the car with the masher 2k's?
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
