thzero
12.09.2010, 09:29 PM
So here's the battle plan for the center diff TVPs. A bit of a different approach. Notice the lack of 'rollbars' built into the TVP. I'm planning on running the Baja rollbars instead so thats some of the reason for the design.
Here are the TVPs. Right now I have it using two 3S batteries inside the rails forward of the center diff. I was debating between the twin batteries, or doing a single battery like I have now that sits just over the top of the drive shaft. But I thought that it might be better to move the weight lower; also using 3S, vs. a 6S, gives me more options to use batteries in other vehicles too.
And here is the new bulkhead/diff plate/motor plate. This will replace the existing Savage rear bulkhead plate. It will hold the center diff using a standard truggy/buggy diff mount. The rear portion of the plate is extended to hold an anchor system for the Baja 5B rollbars.
