12.12.2010, 09:31 PM
The buggy weighs in at 21.8lbs with a gasoline motor, full tank of gas and Jet-pro side pipe as per DemonRC. The Electric will be WAY lighter than that because the gear plate, motor and pipe are gone. The square drives are FG style, what more tire options do you need than that? If you have to run Baja wheels/tires 24mm Baja adapters are in the works by Ramtech. Plus a few other companies adapters can be easily modified to work. In the latest video its running on 6s. I wish they'd offer rollers but I don't see that happening at all.
