MetalMan
MetalMan's Avatar
03.06.2006, 09:14 AM
1. Yes, you can do series. FMA says that you can "daisy-chain" the receiver LVC wires together.
2. The batteries don't provide directly to the receiver unless you use a regulator like a UBEC. With a UBEC, you would connect it to the output of both packs (or on the controller end).
3. Aparrently, charge current is not an issue with the Scorpion packs. They can be charged at 3C (3 times their capacity) without any problems. So, it doesn't matter how you set the charge current.
