ON these life po 4 cells. How many could you run on a 9920. It comes out to 7.5. I was wondering if it would take 8s or not.
I think 7 is the limit. 8 may be too high, but it would be worth a try (IMO) if you have the cash to fry a 9920 (which I don't).
Originally Posted by Nick
What charger would you reccomend to do 6s LiFePO4 at 2C? How many amps is 2C or is it a charge setting?
Thanks peeps,
Nick.
You can use any Lipo charger to charge these batteries. Their rated maximum voltage is 3.65v (their CV voltage), but they are capable of 4.20v. Personally, I use a Li-Ion charge setting, which is to 4.10v, which is easier on the cells.
2C just means that it is twice the capacity of the pack, so a 3600mAh pack charged at 2C is 7.20amps (7200mA).
