12.29.2010, 04:10 PM
Yes, use freewheel on. If it is off, the esc will reduce motor speed when you let off the throttle (no coasting). The acceleration time setting is like punch control... use low time for no (or little) punch control, use higher time for more punch control. I usually use setting 2 or 3 on the low end, gives a little punch control.
