01.04.2011, 02:43 PM
Torque (in oz-in) at the motor shaft is derived from 1352/kv*amperage. There are a couple pages at the R/C Calc site that estimates torque.
However, under load, kv does drop due to copper losses. And amperage is dependent on load (gearing/weight/etc). So any calculated value will be approximate. I don't know of anyone who has "dynoed" their BL setups.
By the way, DO NOT EVER purposely stall a motor. When you do that, the rotor isn't turning (obviously), therefore no back-EMF (resistance). The only thing limiting current when you do that is the copper resistance of the wire, ESC, other wiring, and batteries. Theoretically, a 2200kv Castle motor will draw 3700A on 6s under stall. Of course, that won't happen because something will fry.
