simplechamp
simplechamp's Avatar
01.06.2011, 10:45 PM
Excellent, the diameter is perfect.
The blue spring with 1.9lb rate is supposed to be a longer spring for the RC18T/B rear, the shorter blue spring for SC18 ( and RC18T/B front) is supposed to be 2.55lb rate. So are you using the RC18T/B rear longer springs on your SC18? I'm just trying to figure out if the 31.5mm length is for the front or rear size RC18 springs.
Thanks for the help so far bigsteel!
