01.12.2011, 10:44 PM
I've seen numerous tests running fans @ 5V, 7V, and 12V.
SilentPCReview.com being on of them.
I'm sure it wouldn't matter if I used + or - for the wire that goes through the switch, right?
Well, 5v may work, but may not. You could temporarily wire the fan up to 5v and see if it starts reliably (may "grumble") and has the airflow you want before you make a more permanent switch setup.
