rawfuls
roofles.
rawfuls's Avatar
01.12.2011, 11:58 PM
Aaaaacctualllyyy.......
It does. Either diagram would need to be hooked up exactly as pictured to work properly.
Well......
It's a dang good thing I asked then...
I was gonna just not ask and just hook it up the other way, what would go wrong if I did reverse? Sparks and sparks?
Well, 5v may work, but may not. You could temporarily wire the fan up to 5v and see if it starts reliably (may "grumble") and has the airflow you want before you make a more permanent switch setup.
I have one of the fans that I'm gonna be picking some more up later, so I'm gonna try and test that out this weekend.
If 5V doesn't do much, may just stick to 7V then..
