ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
01.13.2011, 01:39 AM
Well, This isn't looking good.
So I hooked up my rustler's servo to the setup I was running. I had the rustler upside down so not much load at all on the system. Did the quick turning and after a couple seconds. Lights out...
SO, I reset-up the buggy and I soldered that Cap. ( 16v 1000m) to an old servo lead. Plugged it in the Batt terminal on the RX and proceeded to try and duplicate the lights out. It worked perfectly fine. I could slowly inch the tires sideways untill full tilt. Then the other way and do it quick and had no hiccups at all.
I then unplugged the cap from the RX and tried it again. Steering was horrible, It twitched all the way if I slowly went side to side and just would cut out fully if I went quick. Replugged the Cap again and all is well...
Whats up? BEC working, but WEAK?
Last thing I will try and rule out tomorrow is the RX as I have another in the Maxx. But like I said it was working just fine with a RX pack...???
Thanks for the Help I really do appreciate it.
Sean
PS Bluebird is working fine so far and its over a year old for $20
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
