simplechamp's Jammin X2 carbon on-road GT
simplechamp
simplechamp's Avatar
simplechamp's Jammin X2 carbon on-road GT - 01.15.2011, 03:03 AM
Finally putting to use the Moos Racing CF chassis I've had for awhile now. Been collecting pieces for awhile now and finally starting to put it all together
Tonight I built up the diffs, alloy cups all around and hardened steel internals. 50k front, 100k center, 30k rear. For the center I have the Slipperential and built up a standard center diff also.
Rebuilt the shocks. There will be Hyper 9 17mm front big bores and all 4 corners, internally limited, 60W oil and firm springs. Stock pistons to start out. Using X2 CF front tower, and modified X2 CF rear tower. Trying to lay the shocks down quite a bit.
Bought a new steering rack on Ebay and put it together with a Kingheadz ackerman plate. Trying to put some red accents with the concave washers and red bearing seals (don't see much of those though).
Only pics I took so far are kind of a mockup of the layout, still need to make an ESC rack to mount on the back of the center diff. Also still waiting on NEXX8 lipo trays and Kyosho IGT body mounts and front bumper.
More to come soon! (Mods if you think this should go in the buggy section feel free!)
