01.18.2011, 06:30 PM
Just remove the red wire from the connector plug. Lift the little tab on the plug holding the connector in place, slide out the wire/connector, flod it back over the cable, and heatshrink it to the cable. That way, you can easily reverse the procedure if you want to.
