SunnyHouTX
SunnyHouTX's Avatar
01.23.2011, 11:19 PM
Originally Posted by C-5Quad View Post
Wow i'm impressed you get 45 minutes from 5000 mah pack
I never got more then 20 but I run a lot of full throttle wich is why my temps are higher and run time shorter..........if the blower doesnt help ill pop in a 1518 or gear down some...actually ill order a 16 or 15t now and just gear down as well
Yup. I've got mine geared for about 30mph and that's enough for me for now. I will go up a tooth or two on the pinion when I go to the soccer fields but for the space I have now in my apartment parking lot 30mph is enough. And yes, I do go full throttle a lot.
You might have to go to a smaller pinion on the 2200Kv motor if you plan on using it with 6S, or, like linc said, drop the 1518 in. The 2200Kv is more of a 4S - 5S motor in the E-Maxx.
