brian015
brian015's Avatar
01.25.2011, 12:49 PM
Could you rotate the CD mounts 90 degrees so that they would attach to the same TVP that the motor mount attaches to? Keeping the CD in the same position. This would allow the motor to mesh at the side of the CD mount where it is designed to and would free up the top of the mounts for the top plate and brake hardware. What I'm suggesting is using a standard truggy layout for CD and motor - but mounted vertically in your case instead of horizontally.
