Jahay
01.25.2011, 05:57 PM
BRIAN! Thank you!! That should work definitely...! Im going to try it and get back to you on the progress!!!
If you had to recommend an entire centre differential and brake set up OR piece together your ideal centre diff, STRONGEST Brake setup. What would you go for? I am new to centre diff mounts and braking systems.
Thanks
Edit
Linc, i have to cut a plate of alloy anyway... so i am going to look at both possibilities. I want to see which method allows easier fitment of the braking system.
Hopefully if i get this to work then i can settle with the ice hv 160amp...
