Jahay
01.26.2011, 12:11 PM
it is something i would definitely be interested in! But i do believe there is a lot more to it...
Anyway... my braking system is under way, just ordering the necessary parts, and im going to spin the diff mount 90degrees...
Just ran into problems with a hyper st brake cam not working with my alloy diff mounts
As can be seen below
i have decided to run twin pads front and back for ultimate, efficient braking... Im going to run the cradock twin anti lock brakes on the front side of the diff and regular pads on the rear as i do not mind the rear locking up in a turn to sweep the back around a little, but i would not want the front locking up...
As you can see below, twin pads and discs should have plenty of room
