Worked out.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Worked out. - 01.26.2011, 06:11 PM
Glad it worked out for you. Cutting plexi-glass is always a PITA. The tape method is about the best way to protect the project, and even that fails sometimes. Drilling very slowly is also a good technic but can be difficult depending on the type of drill bit used. A hole saw does not cause as much damage as you might think, and should go through the plexi fairly easy although it can leave the edges a little more rough. Plexi-glass used to be all the rave when it first came out, but the brittleness is really disappointing considering what it was meant to present in the way of durability. Lexan seems to be a much better choice. So what ya making anyway?
SUPERMAXX YOUR LIFE.
