Cody.McP
01.27.2011, 08:16 PM
Originally Posted by blackz97 View Post
Seriously? Thats impressive! Were u rippin it? or just putting around? Also what voltage do you have your cutoff set at? If you got almost an hour on 6s then I would expect you would get well over an hour on 8s. An hour on a single charge for a 24lb 5th scale car would be awesome!
Steve
I was blasting it when I was driving, I was racing my Dad's Jammin so there would be periods of waiting to start, but I'd say I was on my throttle for about 80% of the time., I was on mostly loose dirt so my tires would slide all over the place, not sure if that affects runtime though.
And it turns out my ESC is most likely dead. :( I hooked up my 1515 to it and nothing. I hooked up my 2028 to my MMM and it worked fine. The ESC recognizes my throttle input, but it just doesn't communicate to the motor in any way, which is why it won't beep when it starts up, the ESC does "arm" I'd guess, as I get the blinking LEDs and everything, it just doesn't connect to the motor so no beeps. I'm thinking I must have shaken up the ESC too much in my crash and a solder joint went bye bye. I'll give Castle support a call tomorrow but I'll probably be out of a Baja for a week or two.
