snellemin
2 KiloWatt RACER
snellemin's Avatar
01.30.2011, 04:06 PM
I swapped out the Pletty for the Tekno Nue 1515 1.5D motor and ran it last nite with the 28T pinion + 4s Acepow. Calculated speed is around 80mph and it sure looked like it went that fast. I did this run with the Ofna Blue foam tires that has about 2-3mm of foam on the rim. I blew foam ups before with less speed. But I figured because that was fresh uncut foam tires. Lesson learned. The Tekin only had 3 lights on and the motor wasn't even sweating after a few speed runs. Waiting on my V4 eagletree logger and gps receiver to arrive to post some real speeds and verify/tweak my excel calulator.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
