gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
01.31.2011, 06:41 AM
New to the forums? I've seen you around here forever!
I can't believe nobody told you to try a smaller pinion. If you can't try a smaller pinion could you possibly try smaller tires? Cogging is simply too much load, lighten the load.
The quark is nice, but I'd check out castles micro stuff. They even have a 9600kv 20mm motor on clearance for $15 and a few 26mm motors for $25. http://www.castlecreations.com/promo...clearance.html
after re-reading the thread and looking at the pics i'm sure putting the stock tires back on would help.
you gotta gear down or motor up.
It did the same thing with the stock tires with a stock setup. There's a few others that have the same problem. I'll try the smaller pinion although this is a tiny motor for this size of a truck. Oh and I copied the text from another forum because I was in a hurry, haha.
I'll look into the Castle stuff, I wanted to run a Sidewinder Micro but didn't want to spend a ton. I might be able to swing for those 20mm motors though.
:D
