Thread: Weird MM issue
Thomas Porfert
Thomas Porfert's Avatar
02.01.2011, 01:08 AM
I completely turned the lvc off, made no difference.
The red led flashes when EXCESSIVE voltage is read. So I guess this is some sort of overvoltage protection, guessing 3s lipo fully charged is max allowed by this firmware revision?
This is correct. The engineers chose to add an over-voltage protection into the newer versions of firmware. If you go over the rated voltage on the controller, the red LED will flash quickly in the event of over-voltage and prevent you from using the controller. Just roll the firmware back to an older version and it will still work.
Thomas Porfert
Tech Support
