02.01.2011, 05:07 PM
These are the listed Viper motors.
KVCase Length 72mm 1400kv 1700kv 2000kv 2300kv 2600kv
KVCase Length 77mm 1300kv 1600kv 1900kv 2200kv
Case Length: 53.80mm
Case Diameter: 42.00mm
Shaft Extension: 5mm
Shaft Length: 18mm
Default Rotor Spec: 13.8mm
NOVAK
Ballistic 8 (43.5 dia x 71mm);
Ballistic 8L (43.5 dia x 76.5mm)
5mm x 18mm Output Shaft
Tekin
Shaft Dimensions: 19 x 5mm w/flat
Motor Diameter: 1.57” (40mm) / 1.65” (42mm) including fin
Motor Length: 4030: 2.80” (71mm) 4038: 3.0” (76mm)
Bearing Dimensions: Front: 5x16x5mm / Rear 5x11x5mm
T8 (buggy) motors
TT2350 4030 2650kv
TT2351 4030 2050kv
TT2352 4030 1900kv
TT2353 4030 1700kv
TT2354 4030 1400kv
T8 (truggy) motors
TT2360 4038 2250kv
TT2361 4038 2000kv
TT2362 4038 1700kv
TT2363 4038 1550kv
TT2364 4038 1350kv
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
