02.02.2011, 12:18 PM
I consider the 4x4 sc trucks like an 1/8 buggy, so any buggy system should work well.
If you plan to run a MM on 4s lipo you will want a motor around 2000-2500kv.
So we have a 60mm long motor, 4 pole preferably, 2000-2500kv. I am sure a neu 1512 will do, and the the cc 2650 motor should be fine.
There are other options, medusa (if you can find one) tekin, and some of the clones (questionable).
Novak are making some 4 pole motors, not sure if they are any good as they have not been tested/released yet.
If you can scare up an aveox 36/30/1.5y it would be about perfect. I run one in my pede 4x4 on 4s and it does very well with a MM with a ccbec.
