Similar -
02.02.2011, 06:27 PM
Hey Joe I did something similar with one of my trucks mounting the center RCM universal diff setup. I believe it all depends on what your powerplant setup will be. If you are planning to use any real brushless power mounting the diff mount on that aluminum center skid may not be your best bet. I mounted mine on a 3mm titanium plate which gives a considerably stronger platform to keep it from distorting under load. The truck looks nice so far and I am sure that it will turn out much like your other builds, which are incredible. Keep up the good work Joe.
