02.03.2011, 04:48 PM
You would have to use the lst c hub and knuckle as well as the cvd, as the inner bearing captures the cvd pivot pin. And at that point you might as well use the lst arms as they will be the correct length as the lst cvd is slightly longer than a savvy dogbone.
And after putting a set of hd savvy dogbones in I have a feeling they are stronger than the lst cvds. Maybe the cen genesis cvd would be a better choice?
I have seen some savvy owners put the complete cen arm assys on their trucks, wider and stronger.
I still think the lst is a better truck, and if you want cen stuff just buy the whole cen trcuk as it is just like a giant savvy anyways. Very similar designs. Just my take on it all.
