Jahay
02.04.2011, 09:18 PM
If you believe and obviously seem to have tried and realised that the LST setup will not work which is a shame...
But that is promising about the CEN GST
Im a little confused...
The savage you saw had savage rear setup but a CEN GST Front setup...
Does this mean the arms and hubs come out the same distance? So we are not adding any extra width then? Otherwise the front would be wider than the rear?
I was looking at some CEN Parts... They look very robust and the hub/axle/shaft look extremely tough! Hopefully should increase stock savage steering throw as well without the worry of shafts popping out of the axle thanks to the cvds...
What also looks exciting, is as you said... the CEN Lower arms should fit onto a savage bulk hopefully without or with very little modding and shimming possibly???
I would definitely run some baja rims and just use a 1mm thick layer of alloy tape over the CEN GST 23mm hexs.
Please get some pics up...
