Jahay
02.07.2011, 07:40 AM
AWESOME DETAILED WRITE UP! Thanks for all the pics!!!!
there is a thread going, trying to work out the strongest diff combo...
So far we have come up with the
BP Ring and pinion
Nova Hellfire Cup (uses 8x16 bearing) or IRC alloy lightning diff cup.
HotBodies Hardened Spider Gears (larger and thicker than stock savage gears)
This way you have a tough alloy cup getting rid of the 10x16mm bearing
Stronger, thicker internals,
And the strong BP Gear...
BUT if the CEN Gear is a drop in gear and can make use of the savage stock SHD Axles... THAT SHOULD BE A MUCH STRONGER COMBO NO???
has anyone got a full CEN diff to drop in a savage bulk to see if it works with the SHD Axles?
