02.07.2011, 11:49 AM
Thanks Pink, you are such a nice guy.
For reference here are the savvy arms specs.
Hinge pin dia - 4mm inner and outer
Pin to pin length - 120mm
Bulk end - 33.2 inner , 58.26 outer this is measured without the small item that overlaps the pin braces. I did this as I do not think I will find an arm with this feature, and want comparable measurements to the truggy arms
Hub end - 35.2 inner , 50.2 outer
