02.10.2011, 11:29 PM
Nice job linc but I have one question. Wouldn't it have been easier to modify the cvd shaft? Cut the shaft and take out a piece 6mm and then get some tubing that has an ID the same as the OD of the shaft and weld it together. That should result in a shaft that is plenty strong and wouldn't have been much work
Yes, being a welder this would have been alot easier for me.
However I want as amany off the shelf items as possible. And the cvds are a wear item, the braces should last the life of the truck.
