Jahay
02.12.2011, 12:31 PM
looking forward to the build brian...
I am a little out of touch with bodies as i couldnt find anything suitable for my 17" Wheelbase savage so went with the nylon roll cage... 17" wheel base proved to be a weird length... you either have the 1/8 bodies or the 1/5 bodies... one of the large 1/8 bodies i found was the GCM Proline truck body (transformers truck) or the Short course bodies... Really annoying!!!
Can i ask you a quick question regarding the extra bearing you installed in your lst hub please...
Why did you put a 1mm sleeve on it? was it necessary to get it to fit correctly? did you just want to distribute the weight of the axle on the bearing evenly? how well did it work?
THANKS BUD
edit...
Isnt the XXL LST2 around a 17-18" wheel base?
