02.12.2011, 06:08 PM
Picture time!!!
Ok, these show the lst axle with the spacer so that the emaxx center cvd will sit correctly in the revo diff output cup.
And these show the spacer on the other side of the hub, this will not work with the emaxx cvd, but if you had a 8mm longer cvd it would. I plan to cut and weld a lst cvd and use the lst axle this way. I can run a 2wd pede rear wheel (different offset to the 4x4 pede, as it uses 2wd pede front wheels all around) and give the other 2 front wheels i have back to my 1/7th scale pede based tube buggy. With the 8mm spacer on the outside the 2wd rear wheels have excatly the same width as the stock 4x4 pede setup. Nice how that worked out.
Not sure what to do with the front, but I think the stock sliders will be just fine. After the few packs i have run they are not worn or twisted at all. If they do crap out I will likely mod up some lst cvd/axles to work there as well.
Or I could use old tmaxx cvd axles and the lst cvd shafts cut and welded. Here is a pic that shows the old maxx axles v/s the lst axle. As you can see the maxx axle is much shorter and the pin hole is closer to the cvd joint.
