Thread: Savage Diffs
ljoncp
02.14.2011, 06:46 AM
I had this issue recently with GH bulks and brand new BP diffs out of a XL. Turned out the case was not machined correctly and was not the correct shape to fit one of the diff bearings. One of my cases fit fine and the other required some shaping with a round file. Have a look at the bearing areas on the case when you have the diff in. I had what can best be described as a flat spot. Should have been curved to match the bearing.
I'll check this out and let u know what i find. Thanks!
