02.16.2011, 06:26 PM
Cool beans- Ziggy says that setup should give you 48mph, which seems pretty sound & reasonable to me
Differential Ratio: 4.090909090909091
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 15
Total Voltage: 22.20
Motor KV: 1580
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 3.07 : 1
Total Ratio: 12.54545 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Rollout: 1.45:1
Total Motor Speed: 35076 RPM
Vehicle Speed: 48.24 mph (77.5 km/h)
Effective KV Value: 1580
KT constant: 0.86 oz-in/A
