DrKnow65
DrKnow65's Avatar
02.18.2011, 10:31 AM
I also think the slipperential isn't a must have in your application. It is there to protect the drivetrain from the shock of landing with the tires spinning or stopped. If you are just doing speed runs and not building an all-around buggy you should be fine without it.
If your going to build a multi purpose buggy you should consider it.
