Thread: Savage Diffs
02.18.2011, 10:47 PM
Not quite as easy to get into as the X bulks. You have to remove the pin brace bolts on the bumper side, remove the 2 bolts that hold on the plastic skid plate closest to the bumper, remove the shock tower bolts and the 2 smaller ones below them. I like to pull the upper arm pins out.
These are sturdy parts, iff you shim the diffs correctly the only reason you will have to remove them is to change diff fluid.
