02.19.2011, 09:41 PM
You did not touch on balancing your tires, this is the 1st mod you should do to any rc, period. I did my own testing with balancing and taping with a set of badlands and maximizer beadlocks. The difference was amazing, I picked up speed, the straight line and turning stability was greatly improved, I can imagine bearing wear was greatly diminished, and it just made driving the vehicle so much nicer. Plus temps went down on the motor esc and batteries. All you need is a cheap prop blanancer, some sticky tire weights, and a hot glue gun. Maybe I should do a writeup. I can balance a set in less than 10mins.
