Thread: Castle 1410 1y
scarletboa
scarletboa's Avatar
02.23.2011, 02:49 AM
Originally Posted by bruce750i View Post
If the combo just would of come with a esc mounted fan instead of a motor fan. How would you get this motor hot enough to need a fan, while using a Sidewinder without a fan? I bought 2 more combos anyways
i was thinking the same thing.
i have yet to get the motor over 120F, but in my setup, the esc will thermal after 10 minutes of running. there is no rig out there that can make the motor get hot enough to NEED to the motor fan without hitting thermal first on the esc. i plan on adding a 30mm fan to my sct esc once i can figure out how to mount it. should i just force some m3 screws into the fins using the holes already in the fan?
edit: i plan to use the 30mm fan from the motor shroud.
